How would you achieve a 4/6 drop?
Old Jan 17, 2013 | 05:04 AM
  #21
shorty's garage's Avatar
My djm notch fit good and spindles+springs won't change your geometry as much as control arms.
Old Jan 17, 2013 | 05:12 AM
  #22
texasglock23's Avatar
Sure the notch fits...but they also fail causing the frame to buckle and crack.
Old Feb 17, 2013 | 11:43 AM
  #23
bs4.8's Avatar
im using mcg 16" 2" drop spindles,2" ground force coils up front,rear is the new style djm flip kit..throw away their notch though,buy a belltech or mcg ..djm I guess bend..I havent personally had issues with thedjm notch cause I read up first before buying anything,but after having the nnotch in my hands I wouldn't use it..its just a plate with a c welded to it,and the c is welded on the front,if you flip it over you can see the 1/4" gap between the c and plate that's not welded up.I have run djm spindles,sways,coils on ton of trucks with zero issues but their notch looks very weak
Old Feb 18, 2013 | 04:10 PM
  #24
If you get the DJM notch, just bolt it in, then have it welded up, that should be more than sufficient, but I would spend my money elsewhere.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chewy07
Nov 14, 2015 09:46 PM
vmaxpro
Sep 28, 2015 11:10 AM
twake_410
Sep 25, 2015 10:09 PM
pewter00
Sep 11, 2015 09:32 AM
