How much drop from torsions before realignment needed?
Old Aug 1, 2005 | 11:31 AM
TG02Z71's Avatar
Default How much drop from torsions before realignment needed?
I did the 2" rear lift block and removal last weekend and backed my torsion springs down anout 8-10 turns.
It looks good and drives fine but how much is too much before I'll need a realignment from th edrop in the front?
Old Aug 1, 2005 | 11:34 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Me personally I would only go about 6-8 and thats it after that you are going to start running into problems IMO.
Old Aug 1, 2005 | 12:25 PM
You should get an alignment no matter what. Anytime you mess with the suspension geometry you should get one. Having to buy a new pair of tires is much more expensive then a front end alignment and lost time.
You'd be surprised what -1 degree of camber can do. Or even .5 degrees of toe-out can do to a set of tires.
Old Aug 1, 2005 | 12:50 PM
white1's Avatar
You're suposed to get it re-aligned anytime you mess with the torsion bars. That doesnt mean I do, but you're suposed to. I would just get the height where you want it, make sure both sides are the same, and then get it aligned
Old Aug 1, 2005 | 01:35 PM
Zick's Avatar
When I raised my last truck about 3/4" - 1" it threw my alignment off. Not enought for me to notice but when I had it check it showed to be off.
I agree with the last two post, anytime to mess with the suspension & steering always get it aligned or at least checked out.
Old Aug 1, 2005 | 03:27 PM
Black Nali's Avatar
I did the same thing last year. Lowered it probally 2-1/2" and I couldn't tell it was out until I noticed my friggin new toyo's were starting to wear. Do yourself a favor and get it aligned.
Old Aug 1, 2005 | 03:50 PM
TG02Z71's Avatar
GREAT!! I'm going on a 400 mile round trip drive for wotk tomorrow morning with no time to get it done before that. Guess it will have to wait.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
