How much drop from torsions before realignment needed?
I did the 2" rear lift block and removal last weekend and backed my torsion springs down anout 8-10 turns.
It looks good and drives fine but how much is too much before I'll need a realignment from th edrop in the front?
You should get an alignment no matter what. Anytime you mess with the suspension geometry you should get one. Having to buy a new pair of tires is much more expensive then a front end alignment and lost time.
You'd be surprised what -1 degree of camber can do. Or even .5 degrees of toe-out can do to a set of tires.
You're suposed to get it re-aligned anytime you mess with the torsion bars. That doesnt mean I do, but you're suposed to. I would just get the height where you want it, make sure both sides are the same, and then get it aligned
When I raised my last truck about 3/4" - 1" it threw my alignment off. Not enought for me to notice but when I had it check it showed to be off.
I agree with the last two post, anytime to mess with the suspension & steering always get it aligned or at least checked out.
