How much atf fluid needed for stall and larger cooler install?
Old Dec 5, 2007 | 01:33 PM
sharpshooter's Avatar
Default How much atf fluid needed for stall and larger cooler install?
Doing this Friday and need to know how much fluid to buy.
Old Dec 5, 2007 | 01:55 PM
Also do you guys use a rachet wrench [size ?]on the flexplate bolts?
Old Dec 5, 2007 | 07:14 PM
00stepsyde's Avatar
I ended up using right between 12/13 but I had a shift kit put in at the same time, so it might not take quite as much. My tranny was completely drained. If you are talking about the TQ converter bolts, they are hex head, and I used a 10mm allen head socket.
Old Dec 5, 2007 | 09:08 PM
thanks man
Old Dec 5, 2007 | 09:44 PM
nonnieselman's Avatar
10mm???
Mine were 8mm... and be really careful when removing them... they strip really easy.
Ive got ARPs now... 1/2" socket is aot nicer.
ZONES89RS
21
Sep 24, 2015 05:58 PM
cbhedrick
Jul 20, 2015 10:12 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
