How long do you think a 4l60e would last on 4-5psi of boost
#24
Formerly ScreamingL
most of the GMT800 trucks have a very weak 60 even if it was built, the later designs are better inside and out
but in the end a 60 or 65 isnt nothing more then a remodeled 700r4 which was always a GM weak trans...was meant for light cars and trucks...
#25
Agree to a point; a bad tune can kill a built trans, but a great tune can't save a weak trans. I have a great tune with stock line pressure, very mild shift firmness and plenty of tq management left in, and I still snapped the input shaft in two in the middle of third gear and destroyed the front planetary
#26
Even a stock 4l80 input shaft will reliably hold 750 hp and the output shaft is, for all intents and purposes, unbreakable
#27
I'm with choda on this one, I ran my stock 60 just vette servos, with stock cooler and towed 8k lbs. Several times just use third locked on hills. Since then I put a cooler in and tow 6k lbs with no issues. And at times 35000lbs like in my video
#28
Yet a stock 5.7 Express NOT towing killed one in ~38k and a mildly cammed 5.7 in the same van killed a 65E spec build in 40K. That was two transmissions before 80K. My buddy rode in my Express with the 80E and I was just driving it around normally and he asked me if the trans was "BUILT". 60/65e and even 70E are TURDS compared to an 80E or 85E.
#30
Especially when you tow. You will really like the 80E once you get your gears in the right range for your tire size to overcome the tall 1st and 2nd gear ratios.
