How long do you think a 4l60e would last on 4-5psi of boost
Old Jun 25, 2015 | 06:27 PM
MileHighSierra's Avatar
Awesome...you rule. The community here seems legit as hell, thank you.
Old Jun 25, 2015 | 07:27 PM
Fast355's Avatar
Originally Posted by MileHighSierra
Do you have any pics of your tranny cooler setup? I was thinking of doing that as one of the first mods on the truck to keep this 60e happy until I build a 80e.
I need to get some good pictures, but it is litterally a pair of OEM cooler mount brackets from the junkyard with the OEM cooler removed by drilling the rivits out and riviting on a large Derale cooler plumbed with -6 an lines. Its a little different mounting than you would run since its a 97 Express van.
http://m.summitracing.com/parts/DER-13950/
Old Jun 25, 2015 | 11:53 PM
Damn....that cooler looks awesome! How do you control the fan on it?
Old Jun 26, 2015 | 06:11 AM
Fast355's Avatar
Mine came with a thermostatic switch that turns it on at IIR 175*F. Since I already had it plumbed to the stock cooler and have a duramax fan blade on my Express, I put the temperature switch in the return outlet of the trans cooler. So far the fluid stays under 200*F even towing 7,000+ on a 105*F day.
Old Jun 27, 2015 | 10:50 PM
Choda's Avatar
My 60 is holding 500 wheel no prob.
Your goal of 400 is more than fine.
Old Jun 27, 2015 | 10:57 PM
TX Tahoe Z71's Avatar
I'm on my 4th 60E, 3rd built one, at 450-500rwhp. Wish I had gone 80E from the beginning.
Old Jun 28, 2015 | 04:35 PM
03 silverado's Avatar
I'm still pushing my stock 60e on 4-5lbs with no problems at all. It's been about 2 months and it has 215,000 miles on it I just run a tru cool 40k tranny cooler
Old Jun 28, 2015 | 07:34 PM
Suburbazine's Avatar
A 60E will do about a day on boost with a trailer. An 80E will do about an engine (give or take a little), on boost, with a trailer.
I tow a LOT with my 80E and a big honkin' converter on 3.73 gears. I stay in 4th/Lockup all the time except on steep inclines when I step down to 3rd/Lockup for some extra torque. Assuming no serious headwind, I can comfortably roll 5000# on the interstate. When I go dually and 4:10 gears I should be able to pull even more.
Old Jun 29, 2015 | 01:03 PM
Interesting. I'd say my truck at this altitude makes about 180rwhp. If i could snag another 50-60whp out of it, it would essentially be like a bone stock truck at sea level.
Either way, clearly the 60e wouldn't last very long if I'm pulling a racecar behind it. Although i've considered just flat towing one to save weight.
Will any 80E be suitable for a swap? I found a 1991 4l80e for 150 bucks as a builder here in Colorado.
Old Jun 30, 2015 | 09:28 AM
tgui's Avatar
Please tell me you're going dually with your Suburban!
droool....
