How hard to swap out Converter?
Old Jul 20, 2006 | 05:25 PM
14 Second Truck Club
Default How hard to swap out Converter?
I want to get a Yank 2600 torque converter and do the install myself. I have no experience with installing or removing anything in the transmission or motor. Is there a link with pics somewhere on how to do this step by step? Thanks.
Old Jul 20, 2006 | 05:29 PM
Colby 04's Avatar
get a transmission jack, you'll be glad you did. I can't speak much on the install, I installed mine with the engine removed.
Old Jul 20, 2006 | 07:08 PM
Nick™'s Avatar
basically you'll be removing the transmission and replacing it.
pull driveshaft, tranny cross member, wye pipe, starter, torque converter bolts, bell housing bolts, tranny jack supporting tranny pull it off the motor. Lower it, pull off old converter (slides right off), fill new with fluid, put in tranny (3 steps in as you rotate), put tranny back on in reverse order
Old Jul 20, 2006 | 09:26 PM
adrenalinep's Avatar
Old Jul 21, 2006 | 02:34 PM
miesrules's Avatar
I looked for this last week. It's on an F-body, but there are similarities.
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old Jul 22, 2006 | 07:34 AM
How do you pull the driveshaft?
Old Jul 22, 2006 | 09:55 AM
Colby 04's Avatar
where it attaches to the rearend, there are straps that hold the u-joint together. Take those straps off and it will drop, then drop the carrier bearing(if you have one).
Old Jul 22, 2006 | 02:38 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Just make sure you have the converter all the way in when you reinstall it. If not, it will at minimum blow the pump out of the trans. If you can't get some help from someone who has done it before, it would be better to pay someone to do it. Not trying to discourage you, just forewarning you.
Old Jul 23, 2006 | 08:28 AM
FLT's Avatar
FLT
FormerVendor
I have to agree with badmofo. It some times cheaper to have a pro do it.
Old Jul 23, 2006 | 08:38 AM
82streetshow's Avatar
plus pulling a trans out in ur driveway is just a pain in the *** i would not want to experience
lo&sloSierra
Jul 24, 2015 07:03 PM
Ketis
Jul 23, 2015 12:37 PM
Deceptarado
Jul 8, 2015 05:24 PM
mrgrim
Jul 8, 2015 08:12 AM
Nimoryan
Jul 5, 2015 03:50 PM
