High Speed rear end noise?
Old Jan 16, 2006 | 10:33 PM
onebadrubi's Avatar
Default High Speed rear end noise?
When im runnin 105+ or so my rear end makes a small rattle that shakes the hole truck. No shaving in the diff. Nothin abnormal. I did have 4.10's installed and the people that did it said the rear end was in Perfect shape. But at high high speeds its just a constant rattle almost the ring is rubbin somethin but its not. Anybody know what this might be?
Old Jan 16, 2006 | 10:52 PM
Rhino79's Avatar
9 Second Club
Did they install a new pinion bearing? Have you ever replaced your u-joints? Your exhaust isn't rubbing the frame/ crossmember anywhere is it?
Old Jan 16, 2006 | 11:13 PM
smooth_addictions's Avatar
check the u-joint. what lube are you running? and is this shop repitable?
Old Jan 17, 2006 | 11:07 AM
onebadrubi's Avatar
The shop is repitable. All they do is circle track cars and Trucks. I think they did install new pinion bearing. Never replaced U-joints.
pjb1972
Sep 17, 2015 02:06 PM
Ketis
Jul 23, 2015 12:37 PM
ullose272
Jul 19, 2015 04:14 PM
Sdailey
Jul 13, 2015 09:17 PM
