In here....
Old Dec 29, 2005 | 05:53 PM
12sec.5.3's Avatar
Did you space yours to 1/8 of an inch also?
Old Dec 29, 2005 | 06:12 PM
99Silver6.0's Avatar
I only slid my converter out 1/8 of an inch. Then used correct sized shims accordingly to take up the remaining space.
Old Dec 29, 2005 | 06:39 PM
12sec.5.3's Avatar
I gotcha. Hopefully this will cure my problem.
Old Dec 29, 2005 | 06:48 PM
I think it might. Ill hope with you!!
Old Dec 29, 2005 | 07:10 PM
dewmanshu's Avatar
Moderately Differentiated
Not to throw in wrench of an idea...KANO seems to have it down...but I lost 3 pumps on my 60e before I finally took it to a trans shop that deals with high HP alot and he found that I actually threw my throwout bearing. Nothing was banging around in bottom end yet...but was throwing a/c belts and loosing pumps. If you run into the same problem keep that in mind. It is supposedly unheard of in the automatic transmissions, but happened to me. Good Luck. I am definitely trans dumb and never claim to know alot about them, but my wallet sure hurt after that experience of listening to converter and flexplate ideas.
Old Dec 29, 2005 | 08:00 PM
12sec.5.3's Avatar
Hopefully that's something I don't have to worry about.
Old Dec 29, 2005 | 08:50 PM
Kano's Avatar
Originally Posted by 99Silver5.3
Like Kano said. If it has the vac mod kit, that is what adjust line pressure. Nothing else. Shimming the converter is very important. I spent a good amount of timing setting up the spacers on my flexplate. Tight spot didnt make it easy to place them in between there and threading the bolts. I also had to grind a small section off the ends my verter bolts. They were a good bit too long.
I done he same thing
after all that hard work I noticed all three bolts were bottomed out with the spacers spinning freely
Another thing I did was take a flat surface like mirror or glass and sanded rhe spacers down until they were exactly the same
I checked the thickness with calipers
greatbeefalo
Mar 4, 2014 01:09 AM
thechevyman
Feb 10, 2014 09:50 PM
rijrunr
Oct 6, 2013 11:59 AM
sprayedenali
Jul 30, 2013 09:54 PM
