2500HD axle into 1500?
Old Mar 3, 2014 | 10:51 PM
greatbeefalo's Avatar
Default 2500HD axle into 1500?
Heyo fellers, new here....
So Im redoing my 2000 Silverado 1500 after a nasty oil pressure loss...swapping the 70mm turbo for a 88mm and a built motor. Anyhoo, I pulled the axle from a 2007 2500HD 4x4 to put under my truck. All the mounting points look the same, which is great--but can anyone tell me what is the minimum size rim to fit on those big brakes? And anyone know of a company that makes the same rim for both 6 bolt and 8 bolt patterns?
Old Mar 4, 2014 | 01:09 AM
Suburbazine's Avatar
I'd run wheel adapters if you're gonna mix-n-match bolt styles, so your front tires can be rotated to the rear.
Robot Check
Ignore the stupid "robot check" message above, it's an Amazon link.
flatblack83
Jan 3, 2026 07:10 PM
Jake99
Oct 14, 2015 05:55 AM
69z-28
Sep 21, 2015 07:31 AM
FlowmasterMufflers
Sep 18, 2015 02:31 PM
zblee
Sep 17, 2015 07:58 AM
