HELP! Technical Advice Needed for C-Notch Issue
Old Mar 13, 2011 | 10:13 PM
rkwhite61's Avatar
Default HELP! Technical Advice Needed for C-Notch Issue
Ok, so I'm in the process of cutting my frame for my DJM c-notch. However, I noticed this raised area on the frame that will prevent my c-notch from installing flush against the rail. See pics. Note: the fine line tape will be the c-notch cut out.
Anybody else seen this on their c-notch installation (btw.. truck is a 99 rcsb)?
Will I be ok cutting out all of the raised areas so the c-notch will fit flush? Seems like it will be a huge opening or should I try and mount the c-notches on the inside of the rail. Surely, I'm not the only one that has this type of frame. Thanks in advance for the help.
I posted on FSC this morning, but no responses.
Old Mar 14, 2011 | 11:32 AM
rkwhite61's Avatar
I think I finally found the problem. I sent Tony (aka Norcal SS over at TBSSOWNERS.com) a note. He knew right away I have the rare 5" frame. Apparently, some 99-00 trucks have this frame rail. Solution is a Belltech c-notch made especially for this frame rail.
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
