help - service 4wd 2004 Silverado
Old Aug 10, 2012 | 10:26 AM
Tootall's Avatar
Default help - service 4wd 2004 Silverado
Thought that it was the dash switch again. Replaced it and its still flashing.
The t-case actuator is $360+
What's next? Dash buttons have no lights
2004 3/4 ton 4wd 6.0 4L80
Old Aug 10, 2012 | 10:32 AM
chriscon7's Avatar
Not totally sure, but look into transfer case control module... or something along those lines. Depending on your condition, it may be the problem. Hard to tell otherwise. But do some research on it first
Old Aug 11, 2012 | 06:47 PM
geareater's Avatar
have you messed with any of the connections in the harness? follow it all the way up to the connection in your fuse box, make sure its all together. mine did the same thing after I swapped in my 6.0 and I had missed one little connection.
A new actuator shouldn't be $360, I bought one for around a bill and swapped it in myself, all you have to do is pull the skid plate and loosen it with some channel locks.
Old Aug 11, 2012 | 07:12 PM
smokeshow's Avatar
Mod with training wheels
Did you blow a fuse?
Old Aug 11, 2012 | 08:15 PM
TXSZ66AVLANCHE's Avatar
Find someone that can read transfer case codes, it will save you lots of time.
Old Aug 11, 2012 | 09:12 PM
scooter k's Avatar
I'm guessing the TCCM is in sleep mode still. There is I believe a reprogram for this. You can sometimes remove the power from it and power it back up to
wake it up. Otherwise if that doesn't work it will need to be replaced. Put a lot of encoder sensors in too.
85SS/85GN
Aug 7, 2015 04:30 PM
cams 98 silverado
Jul 31, 2015 07:36 AM
Allgonoshow
Jul 29, 2015 04:21 PM
gafool
Jul 28, 2015 05:20 PM
MileHighSierra
Jul 22, 2015 11:19 PM
