Help plz
Old Nov 27, 2010 | 01:48 PM
Sinistersilverado's Avatar
Default Help plz
I recently lowered my extended cab silverado. did a flip kit and lower control arms. I need help on how to instal the carrier bearing because my drive shaft keeps making popping noises if i try driving without it. I've gotten underneath the vehicle to see if i can put the bearing more less how it goes but it just doesnt seem right. Also its a 4-6 drop if that helps
Old Nov 27, 2010 | 02:19 PM
viciousknid's Avatar
Where's the Beef?
Sounds like you need to adjust your pinion angle to me.
Old Nov 27, 2010 | 02:41 PM
Mangled03gmc's Avatar
Baltimore Whore
Old Nov 27, 2010 | 02:45 PM
ok, so how would i go about to adjust my pinion angle? i just tried moving the rearend around and facing the pumpkin more down. what would i use to measure degrees and what should the degrees be at? also do i need to install the carrier bearing first to find out for sure if it's the angle
Old Nov 27, 2010 | 02:49 PM
Baltimore Whore
This was easier then typing it all out
http://www.carcraft.com/howto/91758/index.html
http://www.stu-offroad.com/axle/pinion/pinion-1.htm
Old Nov 27, 2010 | 03:04 PM
so from what i have read on the stu-offroad site all i have to do is set my rear shaft at 25 along with the pumpkin? can i keep my stock carrier bearing on or should i install the djm carrier before trying to set the angle?
Old Nov 27, 2010 | 09:37 PM
.James.'s Avatar
i would install the carrier bearing, i had a local member do mine when i was 4.5/7, and i had no problems whatsoever, install the carrier bearing, its meant for 2 piece driveshafts
00Silv4.8
Jan 30, 2008 12:02 PM
xdanny510x
Nov 7, 2007 08:23 PM
*WILDSTYLE 5.3*
48
Jun 4, 2006 12:33 AM
*WILDSTYLE 5.3*
Feb 13, 2006 09:32 AM
