HELP with my 4l80e swap vss
Old Nov 3, 2012 | 11:43 PM
osolow's Avatar
Default HELP with my 4l80e swap vss
I have a 05 chevy 1500 2wd. Did a swap with a 01 4l80e trans. I got the frost conversion wireing harness.
My question is: I have 2 speed sensers on the 4l80 and my 4l60 harness only has 1 plug. What do i need to do? I was told it wouldn't shift right unless they r both pluged in. I have been searching, but still don't understand what to do.
Old Nov 4, 2012 | 01:09 AM
Bluchevypick's Avatar
I dont know about the frost conversion harness but when i put my 80 in i used the stock harness and i had to run the wires from the rear VSS to the PCM and pin them.
Old Nov 4, 2012 | 01:17 AM
black04's Avatar
With the frost harness you don't need the front iss.
Old Nov 4, 2012 | 01:21 AM
osolow's Avatar
Are you sure about that? I have been trying to get ahold or frost with no luck. I just don't want to mess up a new transmission.
Old Nov 4, 2012 | 01:25 AM
black04's Avatar
Are you using this harness with the relay?
TunedByFrost.com - Products
If so then yes I am sure.
Old Nov 4, 2012 | 01:30 AM
osolow's Avatar
That is what i have. Thanks for the help bro.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
GreyChevy
Jul 7, 2015 08:57 PM
