help geting rid of abs stuff
Old Jan 2, 2007 | 08:42 PM
parish8's Avatar
single digit dreamer
Default help geting rid of abs stuff
i am having a good time cleaning up the junk under my truck and would like to get rid of the abs set up. that pump looks prety heavy to me.
on the master cylinder, does the front goto the front and the back goto the back? i guess i could bleed some fluid out and see wich half goes down.
do i just need to t the front and take it to the apropriat side of the proportioning valve? the back only has one line so i guess i just tie that together bypassing the abs pump.
Old Jan 2, 2007 | 08:48 PM
silver-mod-o's Avatar
Hunt&Fisherator
you are doing away with the ABS completely???? I am almost 100% sure the front goes to the front part of the resevoir and the back goes to the back... sounds like you have the right idea of how to get rid of it... any reasons other than weight savings???
Old Jan 2, 2007 | 08:51 PM
parish8's Avatar
besides abs being completly useless? no just weight.
i hate abs. it is made for people that dont know how to drive.
Old Jan 2, 2007 | 08:55 PM
Hunt&Fisherator
this is true... I hate for a vehicle to think for me... you could probably get 20lbs off it by taking all that junk off and pulling all the associated wiring.
Old Jan 2, 2007 | 09:03 PM
getchusum99's Avatar
abds can be a pain in the ***, i work for ford and mess wit habs problems on cars all day long.i can say though taht ive never had any problems with the abs on my truck and its got 215k on the speedo.parish ,where are some links to soem of your video's?
Old Jan 2, 2007 | 10:29 PM
dirt track racer 81's Avatar
i agree..i hate abs..the first week with my old truck that had abs i was a on a muddy road at an intersection and i went to pitch the truck side ways with the gas and brake pedel like i do with the circle track dirt car to turn the corner and the abs kicked in and wouldnt let the front brakes lock like i wanted and i went straight into the ditch..
Old Jan 2, 2007 | 11:24 PM
Phantom's Avatar
11 Second Club
Idiot
Old Jan 3, 2007 | 12:05 AM
JJ_TURBO's Avatar
11 Second Truck Club
Make sure to take pics, I would like to do the same thing.
Good luck.
Old Jan 3, 2007 | 12:55 AM
RandomHero's Avatar
ABS is a joke. Then again when my ABS module failed, I shelled out $475 for a new one. I ran my truck without ABS for 6 months. I never made my truck skid once. I don't even know how to drive very well. If anything, it hurts you in some instances. If you hit any gravel, a dip in the road or anything non flat, your ABS goes haywire and you're screwed.
I would think between at least the pump and module, thats 25 pounds, plus all the lines.
Old Jan 3, 2007 | 01:24 AM
The rearmost line goes to the fronts.
The proportioning valve goes on the rear brakes.
May want to also do a line lock while you are at it.
