Help with differentials 2500
Old Mar 7, 2006 | 05:38 PM
ihdude's Avatar
Default Help with differentials 2500
I own a 2001 2500 LD 5 speed manual transmission 4x4. I want to know what size is the front differential and what size is the rearend. How can I confirm this? Can I measure something? Any help is appreciated.
Old Mar 7, 2006 | 06:09 PM
Mort's Avatar
Cool
The specs I have are for a 1500HD,2500LD but with the 4L80E and LQ4. You have the 5 speed so I am not sure if they are the same or not.
Front Diff: AAM925: 235mm Ring Gear, Axle Torque Capacity 6300Nm, Gear Ratio Range 3.42-4.56.
Rear Diff: AAM950: 240mm Ring Gear, Axle Torque Capacity 6800Nm, GAW rating 2700Kg, Gear Ratio Range 2.93-4.88.
Old Mar 10, 2010 | 10:09 PM
kbroxson's Avatar
Registered User
I have this truck, as far as i know you will have the 10.5 rear with 4.10 gears and the 9.25 front. Hope this helps
calsdad
Jun 14, 2023 11:07 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
murderedSS
Sep 27, 2015 10:16 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
