HELP Advice Needed Open Rear end Blew..again..
Old Jan 19, 2011 | 09:31 PM
TrickyTransAm's Avatar
Default HELP Advice Needed Open Rear end Blew..again..
Alright,
I'll keep it short, as I need help very very soon.
99 Sierra 1/2 Ton 4X4
3.73 Open rear end.
Spit second set of spiders out today.
Need to have the differential completely rebuilt by a local shop
What parts do I need to make this stout enough to handle 400 ft/lbs+ of torque?
Extremely tight budget, but want to do this once and only.
I didnt want to swap axles if I didnt have to. Prices I'm being quoted are around $1200 for replacement parts.
Eaton Performance Posi?
Any specific bearing/seal kits preferred over others?
Old Jan 19, 2011 | 09:33 PM
00ChevyScott's Avatar
Wearin' da big hat
Originally Posted by TrickyTransAm
completely rebuilt
None of those go together easily, but if I were you I'd get with Rons Machining Service and get his package deal with a trutrac/gears/bearings/install kit.
Old Jan 19, 2011 | 09:42 PM
Looking those up now.
I saw one on here for the GM kit for $600, but I dont believe it was Rons.
What would be the typical install cost do you think?
Old Jan 19, 2011 | 10:28 PM
AJII's Avatar
That sounds about right for Rons.
Install here runs $250
Old Jan 19, 2011 | 11:36 PM
THE-HOE's Avatar
You say you only messed up the spiders? So your ring and pinion is still good? I would just get a truetrack and a master install kit, and re use the ring and pinion. This is what i did back in 2006 and it is still going strong to this day.. has seen a cammed and full bolt on ls2 and a turbo lq9, so im sure you would be good for 400ft tq.
Old Jan 20, 2011 | 12:20 AM
Stoichiometric's Avatar
I agree. You are not going to put down 400ft/lbs with an open differential and the spider gears will not appreciate the one wheel burnouts.
Old Jan 20, 2011 | 09:17 AM
I'm hoping so. It was good the last time, just the spiders were trashed.
I'll drain it tonight and get the big chunks out.
I know that there are particles all through the rear, so all seals/bearings will need to be replaced. Probably more than I can do myself. (never tore into one).
Is that an Eaton Truetrack or Detroit locker?
I want it to work like a traditional posi, not a ratchet etc.
For seals/bearings, is there an "outer kit" for a complete set or?
pjb1972
Sep 17, 2015 02:06 PM
Oobray
Aug 12, 2015 10:56 AM
So.cal Wrk Sled
Jul 26, 2015 12:10 AM
Ketis
Jul 23, 2015 12:37 PM
