Having to replace the intermediate shaft again.
Old Feb 14, 2010 | 04:15 PM
BigD50's Avatar
Default steering shaft
hmmm oh well i got the oem part for a good discount off of ebay brand new so I will just put this new redesigned one on. It looks to be a little tricky perhaps from what i have been reading...the gm serv bulletin says u need this pin to keep the steering wheel straight and you ahve to remove the accelerator pedal and slide this thing in and out thru the steering column so i mgiht just pay someone....
Old Feb 21, 2010 | 12:37 PM
qwank's Avatar
I've seen the lower column bearing wear out also and cause the same noise.
Old Feb 21, 2010 | 02:04 PM
BigD50's Avatar
Default reply about steering shaft
hmm. well ill have to replace this and then see....I really hope it is the shaft
Old Feb 21, 2010 | 09:59 PM
budhayes3's Avatar
PT's Slowest Truck
Replacing the shaft is a piece of cake, just make sure that you don't let the steering wheel spin or you could break the clock spring for the air bag. I think that I ran the seat belt through the wheel to hold it in place...it was a long time ago. I didn't have to remove the gas pedal when I did mine...IIRC there's a 13mm bolt under the hood...maybe one under the dash? Can't remember, I re-greased mine using 2 of the factory kits over 5 years ago and my knocking pretty much hasn't come back. Every once in a while with the wheel turned a certain way while hitting a bump I'll get a very slight knock, but nothing like it used to be.
Old Feb 22, 2010 | 06:46 AM
SnakeOiler's Avatar
I am about to replace mine, just got the new updated steering shaft for my 04 yukon 4x4 with gm pat number 19153614...this one work for u guys?
Yes, that is correct.
Old Feb 22, 2010 | 06:49 AM
scooter k's Avatar
The most recent updated shaft has fixed them. I haven't had to do any over again that has the most recent shaft. You would think they could find a fix. They've had this same problem since 1999. 07 NNBS trucks and up don't have this problem
Old Feb 22, 2010 | 11:00 AM
BigD50's Avatar
Default Shaft
Cool, if I take some pics and post them would u guys answer a few questions?I'm reading the serv bulletin andni don't see why I would have to work inside the truck, I seem to see the shaft in the engine bay, but maybe I'm looking at the wrong one idk...
Old Feb 23, 2010 | 04:06 PM
BigD50's Avatar
do you guys see the shaft here?
Attached Thumbnails Having to replace the intermediate shaft again.-truck-shaft1.jpg   Having to replace the intermediate shaft again.-truck-shaft2.jpg
Old Feb 24, 2010 | 09:16 PM
qwank's Avatar
yes, and it goes through the boot in the firewall and the other end bolts up to the shaft coming out of the steering column
Old Feb 25, 2010 | 07:59 AM
BigD50's Avatar
hmmm, ok yeah that one bolt there has to come off then the ones inside the cabin...I know not to let the steering wheel move, GM actually sells a "pin" that inserts into the steering wheel and locks it, but i suppose the seatbelt mthod would work
