hard hi-RPM shift
Old Jul 6, 2008 | 08:09 PM
nojpsht04rst's Avatar
Default hard hi-RPM shift
Ok i got a question the 5spd in my RST i noticed doesnt wanna shift when the revs are higher than 3500. low speed shifts are not a prob.I also noticed it does it worse going into 3rd gear. Is it just the way the tranny is normally or would it seem like there is somthing wrong with it?
Old Jul 7, 2008 | 06:27 AM
JakeBrakeIH's Avatar
our trannys dont really like to be shift at high RPMs because I dont know how many times if front of a bunch of people Ive missed a gear...lol but I think I did read with the F-body cars they drill out the slave cylinder orfice or something to let the fluid get to the clutch quicker...I think another reason 3rd gear is hard to is because it such a big jump from 2nd...Im sure someone else will chime in...
Old Jul 7, 2008 | 10:38 AM
how many miles are on it? If its still relatively new just gotta get those synchro's workin a little more lol.
My truck shifts fine at 6300 rpm, are you tryin to float the gears or clutch it and shift? It seems a little wierd the first time floating em at higher rpm but it's fine.
2-3 is a BIG skip on the NV3500, the gearing is so f*cked up on em. 3rd is like the cruise around town gear so it's lowered for more speed than acceleration.
Old Jul 7, 2008 | 10:59 AM
the truck has around 76k on it. and im just shifting regular but i noticed it more when im driving normal and just kinda holding out the revs before i shift. but it really started doin it last week i got on it and missed 2nd next thing i know 3rd was really hard to get into. im really hoping its not the trans because i wanna start doing some work on the truck
Old Jul 7, 2008 | 07:48 PM
well if your holding your rpm it's gonna be a little harder because your dealing with the engine brake effect, how the fck did you miss second an go to 3rd i could see missing second and going to 4th but wtf?
just a reminder, you might wanna change your trans fluid as well if you havent before.
Old Jul 8, 2008 | 11:37 AM
the trans fluid is less than 3k old. nah i missed 2nd, backed off and went in to 2nd. then after that i noticed that 3rd gear was alil harder to shift into at hi rpm. I'm not that retarted that i miss 2nd and hit 3rd lol
Old Jul 8, 2008 | 03:36 PM
jhe2003's Avatar
Synchros???? may be?
Does it grind or it just won't go in at all?
If it grinds try this- start off on first above 3500rpm before shifting to second put in neutral, release the clucth, press the clutch then go to second, if it goes in smoothly with no grinding then your synchros are done.
Just something to try!!
Old Jul 8, 2008 | 08:58 PM
its just seems that the shifter tightens up rigt before it'll go in gear. i noticed today driving around alil that if i back off the gas or hesitate when i push the clutch pedal before i shift it'll go in gear fine. im guessing synchros.
Old Jul 9, 2008 | 03:57 PM
jhe2003's Avatar
YEP, I wonder how much would it be for parts and labor to repair?
Since the tranny will be out it will be real easy to install a performance clutch
Old Jul 9, 2008 | 08:33 PM
Red04Silverado's Avatar
Shifting at 5600 here no problems
