Hanger????
I installed the hangers upside down as opposed to the normal way they came stock i just discovered this today, and I'm very saddened by it. So i want to know if it ok to have them installed like that or should i change thier orientation to the original stock position? The Truck has been running on that for 2 weeks and it shakes and shivers when i pass 60 mph only.
Put them llike they should go. Quit driving it like that.
What drop (how low?) and what all did you use to drop your truck with?
Jim
Mcgaughys 3/5 lowering kit do you think the somtimes shivering @ 60 mph is from that?
You add the shims in 2* increments. Start with 2* shims and work your way up until the vibration is 100% eliminated.
The vibration is bad on your u-joints and driveshaft.
Do you have a 2-piece or one piece driveshaft? If you have the 2-piece you will also be needing a carrier bearing relocator bracket.
Jim
No i didn't get the shims you know any website i can buy from ??cause i don't think we have them here..
Here's one:
http://www.stylinconcepts.com/Articl...s/article.aspx
Jim
Can anyone post pic for Hangers after it's installed on right position??
Jim
FlowmasterMufflers
Sep 18, 2015 02:31 PM
Darknight-4
Sep 1, 2015 05:50 PM
