Greasing Slip Yoke...
Old Jun 10, 2008 | 04:57 PM
xlcooplx's Avatar
Exclamation Greasing Slip Yoke...
What kind of grease do you guys use to grease the slip yoke on the driveshaft? Also, how liberally do you apply it? My truck is clunking worse now and I want to see if greasing it will quieten it down. Thanks in advance!
Old Jun 10, 2008 | 05:04 PM
skeet's Avatar
just shoot a few shots of grease in it when installing the DS. i perfer using a synthetic grease, i get from work...
Old Jun 10, 2008 | 05:23 PM
xlcooplx's Avatar
you say a few shots of grease? as in what kind? red bearing grease or what?
Old Jun 10, 2008 | 08:33 PM
Bish's Avatar
I used BelRay waterproof wheel bearing grease because I had lots around for my dirtbike. It seemed to work well in my 01 Tahoe. It even matched the Autotrac II fluid in color
Old Jun 11, 2008 | 07:22 PM
xlcooplx's Avatar
Thanks man. Did it reduce the clunk?
Anyone else?
Old Jun 11, 2008 | 07:31 PM
JB1's Avatar
JB1
yes...use any kinda of waterproof grease...even marine grease. You can get it at wal-mart or anywhere...wheel bearing grease...balljoint grease...even the std red grease.
Shove as much as you can on it, and your clunk will disappear.
Old Jun 11, 2008 | 09:49 PM
yellowdemon327's Avatar
zep makes some really good grease if ya want to spend a little more, excellent in high heat, high load bearing, 100% water proof and will not fling off. its like greenish in color and i highly recommend it. should work perfect for you.
Old Jun 11, 2008 | 09:52 PM
xlcooplx's Avatar
Thanks for the advice guys!
Old Jun 12, 2008 | 11:03 AM
agreif's Avatar
you guys are talking about the outside of the slip yolk that you grease up, or the inside splines that mates to the output shaft on the trans?
Old Jun 12, 2008 | 02:38 PM
budhayes3's Avatar
PT's Slowest Truck
I haven't greased mine yet, but I can only assume that you grease the inside splines that mate to the output shaft.
