got a problem
Old Jan 20, 2010 | 04:17 PM
Black'Rado's Avatar
ok im really stumped now....i got the right install kit.......looks like the detroit is wrong, correct?
Old Jan 20, 2010 | 05:32 PM
Black'Rado's Avatar
ok....i got my stock **** back in until i figure this **** out.......got my parts infront of me and took some pics.......
part number on detroit....looked it up on summit http://www.summitracing.com/parts/DTL-913A481/
bearing i was sent with true trac ac delco part number 942-0095
delco bearing on left.... bearing from install kit on right....notice size difference
bearing from kit fits in housing but inner is to large for tru trac....
Old Jan 20, 2010 | 05:51 PM
Black'Rado's Avatar
found this on jegs------------All GM 8.5"/8.6"Eaton differentials require special bearings. For 28 spline axles with small bearing bores (race O.D. of 2.89"), usually found on vehicles prior to 1999, bearing LM-102949 and race LM-102911 are required. For 30 spline axles with large bearing bores (race O.D. of 3.06"), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required. Will fit 2005.5-07 SAAB 9-7x
Old Jan 20, 2010 | 06:10 PM
Black'Rado's Avatar
ok i am pretty sure i need
bearing LM-603049 it has a 1.6250 bore to fit the trutrac
race LM-603012 it has a 3.0625 outer diameter to fit in my housing
i hope thats all i need?
Old Jan 24, 2010 | 10:14 AM
Black'Rado's Avatar
ok so i got these part numbers......
bearing LM-603049
race LM-603012
and the bearings are still wrong.....the inner diameter is to big...it just slides on to the tru trac???? im really getting frustrated......can anyone tell me for sure the right bearings to use or is the tru trac just wrong!
thanks
Caleb
Old Jan 24, 2010 | 01:26 PM
Black'Rado's Avatar
ok im really gettin pissed.....i measured the tru trac and the outer diameter of bearing surface was-1.625 ok now remembering the partnumber on the jegs page-All GM 8.5"/8.6"Eaton differentials require special bearings. For 28 spline axles with small bearing bores (race O.D. of 2.89"), usually found on vehicles prior to 1999, bearing LM-102949 and race LM-102911 are required. For 30 spline axles with large bearing bores (race O.D. of 3.06"), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required. Will fit 2005.5-07 SAAB 9-7x
i got these bearings and the inner diameter is 1.78?????? WTF the part they say to use doesnt even work? so what in the hell is going on?
I need a bearing and race that measures O.D-3.0625 I.D-1.625
I have had zero luck finding that bearings..........
so please what the flying ***** is going on?
thanks
Caleb
Old Jan 24, 2010 | 02:36 PM
Black'Rado's Avatar
anyone have a clue?
Old Jan 24, 2010 | 02:43 PM
SLOXCAB's Avatar
man i feel your pain i had the same thing happend to me. i was sent the wrong bearing kit so i said screw it and let a rearend shop handle it
Old Jan 24, 2010 | 02:51 PM
Black'Rado's Avatar
its really agravating........because even the bearings that jegs say are needed dont fit
Old Jan 24, 2010 | 04:24 PM
Black'Rado's Avatar
Ok does anyone know what the correct bearing surface measurment is on the detroit tru trac.....everybearing listed to fit it has a diameter of 1.780, but mine measures 1.625?
