Going lower need advice
Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
Mar 26, 2006 | 05:35 PM
virgils4.85spd
Oct 2005
stringer, ms
Which is easier to install lowering coils or spindles? Ill be doing a 2-4.
Thanks,
Derek
virgils4.85spd
Find More Posts by virgils4.85spd
Mar 26, 2006 | 06:59 PM
02BlueStepside
Jan 2004
GA
Coils are easier
02BlueStepside
Find More Posts by 02BlueStepside
Mar 26, 2006 | 08:21 PM
LS1TRUCKGUY
Nov 2005
Deer Park Texas
if you are doing a 2/4, have you looked at the djm 2" control arms? keeps stock spring for stock ride quality....
LS1TRUCKGUY
Find More Posts by LS1TRUCKGUY
Mar 26, 2006 | 08:22 PM
erronisme
Oct 2005
OK
actually about the same...
Spindles are a little bit more work, but not that much more from coils
erronisme
Find More Posts by erronisme
Mar 26, 2006 | 09:10 PM
virgils4.85spd
Oct 2005
stringer, ms
Ok thanks guys
I found some belltech 2 inch drop coils im gonna do. On the rear ill prolly stick with hotchkis leafs. I think it would be ok to mismatch.
Derek
virgils4.85spd
Mar 26, 2006 | 09:15 PM
La Charcoal
Feb 2006
La Joya, Tx.
I have coils and my ride is pretty good.
La Charcoal
Find More Posts by La Charcoal
2014-15 Belltech lift/lowering struts and shocks
BCraven1018
07:18 AM
Advice on light weight 20's
wretched73
09:21 PM
2006 Vortec Max modifications/I need some advice!
gaps
02:53 PM
5.3 to Ls1
Dawas
12:00 PM
Moog Offset bushings
xerox17
01:23 PM
Back to Subforum
View Next Unread
Gm Part # For The Tb Stall
12:26 AM
