Getting Swaybars!!!!!!!!!
Old Dec 29, 2004 | 08:00 PM
  #21
Kano's Avatar
I thought that I heard that you have to move the gas tank or something for the Hotchkis rear bar, while the Hellwig is a direct bolt in. Didn't realize that the Hotchkis was hollow like the factory bars, thought they were solid like the Hellwig.
If I remember correctly that was just changing out the leaf springs.
Either way its no problem just loosen the bands andshift it about 1 in
so the bolt will come out on the front of the leaf
like chingon said there hollow but heavy
Old Dec 29, 2004 | 10:08 PM
  #22
Mr. Sandog's Avatar
From what little applied physics I learned in my search for the idea sway bar, a hollow bar is stronger than a solid bar. This is because, in order to bend, twisting force must overcome 4 surfaces in order to twist a hollow bar (outside top, inside top, inside bottom, outside bottom...if you look at a cross-section of a bar), whereas with a solid bar, once the center starts to twist, the entire bar then becomes easier to twist even further.
Hollow bars are also more difficult to make, which makes them more expensive.
Old Dec 29, 2004 | 10:10 PM
  #23
moregrip's Avatar
what a rush!
explain that to a torsion bar
Old Dec 29, 2004 | 10:12 PM
  #24
Think im gonna do hotchkis!!!!!!
Old Dec 29, 2004 | 10:29 PM
  #25
Mr. Sandog's Avatar
Torsion bars are made to give (and take) for ride's sake, which is why a solid design is perfect for them. As for sway bars, I would rather they hold the inside-turn portion of my vehicle tight to the ground, I really don't want them giving very much at all.
Old Dec 29, 2004 | 10:30 PM
  #26
moregrip's Avatar
what a rush!
hence spring steel duddets!
Old Dec 31, 2004 | 04:08 PM
  #27
Tokez420's Avatar
hollow is better
Old Dec 31, 2004 | 04:17 PM
  #28
moregrip's Avatar
what a rush!
Originally Posted by Tokez420
hollow is better
4 surfaces vs. More Surface Area? hmm, got any proof?
Old Dec 31, 2004 | 05:02 PM
  #29
O3GMC's Avatar
12 Second Club
Got the belltech sways for $300.....front hardly made a difference - rear helped out quite a bit. I'm sure hotchkis are better but I just came across a guy selling the belltech's. I'd just get the rear bar and put urethane bushings in the front.
Old Dec 31, 2004 | 05:03 PM
  #30
moregrip's Avatar
what a rush!
thats what I'm thinking of doing, rear w/front urethanes
