Gears 4x4
Old Jun 26, 2020 | 06:37 PM
hoo-dat's Avatar
Default Gears 4x4
On a 03 silverado z71, what would I need to get to change to 4.10s? They have different options.
https://www.jegs.com/i/Motive-Gear/6...SILVERADO+1500
What are the difference in these 2?
Also, do I need to change the front gears also?
Would this be the correct truetrac needed?
https://www.jegs.com/i/Eaton/362/195...SILVERADO+1500
Thanks!
Old Jun 26, 2020 | 07:20 PM
FFDP's Avatar
You do not have a 14 bolt rear end in a half ton Z71 truck, it will be a 8.5/8.6 10 bolt rear end.
Yes you must change the front on a 4X4 truck.
Yes, that is the correct rear locker. Don't forget that you need the bearing kit to go along with that.
Old Jun 26, 2020 | 07:47 PM
hoo-dat's Avatar
Thanks for the info! Are front gears the same as the rear, so I would just order 2 kits?
Old Jun 26, 2020 | 07:57 PM
FFDP's Avatar
No, the front diff is smaller than the year. There will be specific gears for the 8.25 front diff on your truck.
Old Jun 26, 2020 | 09:12 PM
RB04Av's Avatar
5 Year Member
The carrier you linked to is NOT a True-Trac. It is a standard clutch type posi. It's right for the application, just, not what you're saying it is.
Front is different from rear. Yes it MUST be changed at the same time, otherwise in 4WD, one end of the truck will be trying to outrun the other. Obviously not a good thing: everything in the drive train will bind, and on pavement, the truck probably will hardly even be able to move, let alone drive.
Z71 is irrelevant to the matter at hand, other than, it's only available on 4WD trucks. It's a package with skid plates, upgraded shocks, and STICKERZZZZ!!!!! No mechanical parts are affected. You still have a 1500 truck.
Old Jun 27, 2020 | 08:18 AM
hoo-dat's Avatar
Good info. Can you link the trutrac?
Do people run one in front & back or just rear on 4x4?
Old Jun 27, 2020 | 09:43 AM
FFDP's Avatar
https://www.4wheelparts.com/p/eaton-...R-BHXC-913A481
People only do the rear.
Old Jun 28, 2020 | 10:51 AM
RB04Av's Avatar
5 Year Member
I was referring to the gear ratio, not the carrier, in this comment. Gears & tire size must be the same front & rear in a 4WD application, so that the wheels turn the same RPMs for any given engine RPM at all times.
I suppose you could put a posi in the front, maybe the gear type, but it would make the truck drive rather strangely in poor traction situations... the front would always want to go straight on a slippery surface, and would resist any attempt to turn. Which is why nobody does that. I would advise strongly against it.
https://www.summitracing.com/parts/dtl-913a481 for the rear.
Old Jun 28, 2020 | 11:32 AM
hoo-dat's Avatar
Cool! I've found front & rear gears with install kits plus the truetrac & bearing kit!
Will have these installed when I swap in my 4l80e!
Thanks fellas
Pontiac Derek
Jan 19, 2010 10:03 PM
1320_Racing
Jan 26, 2009 08:25 PM
slow4.7on20s
Aug 3, 2006 08:59 PM
jm's customs
May 19, 2006 01:15 PM
bigguy75inches
Apr 27, 2003 05:27 PM
