gear?
Old Jan 8, 2010 | 10:58 PM
Black'Rado's Avatar
Default gear?
Ok i jus bought a tru trac and want to do a gear swap at the same time...its in my 01 silverado ext cab. I found these http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
But question is....they say 1999 and newer but then it says 1999 2000 with rear disk brake only.....im assuming they fit 01 also, right?
Old Jan 8, 2010 | 11:01 PM
LsxCody's Avatar
they should
Old Jan 8, 2010 | 11:14 PM
Black'Rado's Avatar
im pretty sure they will...just want to check, also anything else i should replace while in there....i want a t/a cover. What fluid should i run? When i put the locker in my blazer i used red line synthetic, but i think i remember reading somewere not to run syn. with the tru trac?
Old Jan 8, 2010 | 11:52 PM
viciousknid's Avatar
Where's the Beef?
with the trutrac you'll run regular 80/85/90 rearend fluid. NON synthetic.
Old Jan 8, 2010 | 11:54 PM
brent5631's Avatar
The gears will work but i think it was in 2000 that there was a change to the bearing sizes. meaning the provided bearings would not work.
Old Jan 9, 2010 | 12:10 AM
Where's the Beef?
Correct. Just take your stock bearing off the pinion and re-use it.
Old Jan 9, 2010 | 01:02 AM
Black'Rado's Avatar
i have ac delco bearings for the carrier....should i just go ahead and get a new pinion bearing?
Old Jan 9, 2010 | 01:09 AM
Where's the Beef?
up to you i guess. I re-used my bearing twice with 150k miles on my truck.
Old Jan 9, 2010 | 01:11 AM
Black'Rado's Avatar
oh...ok thanks for the info...im bout to order it.
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
