G80 question
Old Feb 21, 2009 | 08:19 AM
Dark Halo's Avatar
Default G80 question
My 06 crew cab has a 3.73 gear with a G80, and I think it is humming. I hear a humming noise at 80 and above and it sounds like its comming from the rear end. Any idea?
Old Feb 21, 2009 | 09:28 AM
budhayes3's Avatar
PT's Slowest Truck
At 80 and above? How loud? Could be tire noise, axle bearing, pinion bearing, rear diff, etc. Might need to jack up the rear and run it in the air to listen with a stethoscope...
Old Feb 21, 2009 | 12:00 PM
built408's Avatar
at 80 and above, it could be anything. Usually rear end noise you can hear in the 60-70 mph range.
Old Feb 21, 2009 | 11:54 PM
QLF's Avatar
QLF
My Yukon's and Zexel whine noticeably at 55-60. With a stock axle, whining at that high of a speed, relative to most stock trucks, could probably be a number of things. With as many problems as the Gov bombs have, I wouldn't be surprised though. Check and/or change your diff fluid and bearings, and also check your rear tire pressure.
Old Feb 22, 2009 | 03:17 AM
Dark Halo's Avatar
it does not seem as bad now that I have new tires, I may replace the G80 soon anyway
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
