FYI Lowering nbs 07 Silverado for DIYers
Originally Posted by Allgonoshow
spacers are simple to take out, just a centre tab on them, nothing threaded.
good idea to go to a spring shop to get some big washers, there are no extra threads on the ubolt, removal will give you about 1.25 inches
he's a pic with the whells
https://www.performancetrucks.net/fo...d.php?t=393444
OK, thanks for the info. I might try to find another set of u-bolts, big washer spacers are kinda hack if you know what I mean (I'm fussy). Your truck looks excellent with those wheels....
you don't really need u bolts, a spring shop will have a big fat washer, specific for
u-bolts, or you could get some stainless washers for appearances, much less hack than changing u-bolts,
if you are fussy, i'm ****.
it's more a spacer than a washer, probably 1/4 "
i'd rather have the stock u-bolts with the correct washer than rusty after market
u-bolts.
you are not likely to find factory u-bolts that are shorter than what's ones on the truck, mine is 2wd so there is not much shorter unless it was a 2wd work truck maybe
you could also take the u-bolts off the truck and run a die on them to get a few more threads but that's alot of extra work
u-bolts.
u-bolts.
u-bolts.
If I found aftermarket u-bolts (which they would have to be as you said, GM won't have anything shorter I'm sure) they would get treated before going on.
I don't think I would try to run the threads up any further, thats asking for trouble, I'm sure they are rolled threads and then heat treated so cutting new ones would be risky IMHO. I'm sure lots of guys have done it though.
Thanks for the tips. You gotta wonder why GM added that block anyway, things sit way too high even without that extra inch in there...
no offence taken, we both take pride in our new rigs....
spacer is the correct word, i didn't put a stack of washers in there, would only wear and loosen.
you really need zip space to take up
PS, I have having Nolan @ Campbell's in Edm do my tune.
From what he says it will be a BIG improvement.
I'll let you know when he's done, you may want to look into it.
cams 98 silverado
Jul 31, 2015 07:36 AM
signguy62
Jul 27, 2015 03:42 PM
therock
Jul 25, 2015 09:23 AM
