full specs of a 4L65e tranny part#s and etc...
Old Mar 22, 2005 | 02:13 PM
Faze2183's Avatar
Default full specs of a 4L65e tranny part#s and etc...
i decided to go with a 65 update can you throw all the 65 stuff into the 60 case or????
Old Mar 23, 2005 | 02:30 AM
Faze2183's Avatar
wow intresting
Old Mar 23, 2005 | 05:59 AM
one03sierra's Avatar
Formerly one92rs
Talking
yes!!!!
Old Mar 24, 2005 | 02:28 AM
Faze2183's Avatar
this thread is really alive, whew
Old Mar 24, 2005 | 06:26 AM
Formerly one92rs
Talking
they are going to take all the upgrades and put them in your case. then they should use a beast sunshell and a few other parts for it. man there needs to be more info on this. i forgot all the stuff they did to mine since i went to an 80e.
Old Mar 24, 2005 | 10:50 AM
O3GMC's Avatar
12 Second Club
Here is what goes into a JAG '65
INCLUDES THE FOLLOWING New STOCK PARTS x
Borg/Warner Low Roller Clutch
New Bushings
GM Internal Wiring Harness
GM Solenoids & Switches
Gm 5 Pinion Front & Rear Planet Assemblies
Seals, Gaskets, Filter
HIGH PERFORMANCE ADDITIONS
High Performance Output Pump Slide Spring
Borg/Warner 29 Element Forward Sprag
Steelx.500 Boost valve
Wide Red Band, Performance Lining
"Z" Pack- 15 Element 3-4 Clutches High Performance Application
"Beast" Heavy Duty Shell w/ Bearings & Wide Bushing in Reaction Gear*
HP Forward & Overun Clutches
Borg Warner Low Reverse Clutches
TransGo HD-2 Shift Kit
Corvette Servo
Metal(Aluminum) Accumulator Piston
TransGo Seperator Plate
Hardened Pump Rings
Sonnax 4th Gear "Super Hold" Dual Servo
Wide sungear bushing
OPTIONALx PARTS AVAILABLE
Hardened Stator Shaft - This is listed as an option because we have purchased "Hardened" shafts and have found that they are not any different than those already being used. However, we understand that some people may feel differently.
* "Torque Drive" Unit x(Has "Beast" Heavy Duty Shell)
Old Mar 24, 2005 | 06:24 PM
WillPewter2000's Avatar
someone pm me the price on a jad built 65e
Old Mar 26, 2005 | 07:57 PM
Faze2183's Avatar
if you had ur choice would you use a kevlar band or that new carbonfiber band???
Old Mar 26, 2005 | 07:58 PM
Faze2183's Avatar
and how much is all that gunna be in parts do you have the gm stuff part numbers???
gmcyukon
Sep 11, 2015 10:33 AM
chvy=power
Sep 8, 2015 11:06 AM
mayko
Sep 7, 2015 12:24 PM
Stainless Works
Sep 3, 2015 08:31 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
