Front Sway Bar
Old May 3, 2016 | 09:19 PM
LJ93Z28GM's Avatar
Default Front Sway Bar
The stock swaybar on my 4wd is 1 1/8" / 28.6mm which is the smallest that comes on the GMT800's that I am aware of.
I need to purchase some new bushings so I figured I might as well grab a swaybar from a truck being parted out.
My question is what trucks are compatible? 2wd use the same routing as 4wd? Tahoe/yukon/suburban/avalanche/denali?
I am assuming they are all the same but wanted to verify.
Old May 3, 2016 | 10:09 PM
1FastBrick's Avatar
Custm2500's Rude Friend
No, they are different between 2wd and 4wd.
Old May 3, 2016 | 10:57 PM
Wolftrk99's Avatar
The suvs typically have bgger sway bars, best bet would be to find a junkyard with a few different trucks and suvs and bring a caliper and measure them.... Wanna say the suburbans, 2500s and the escalades have the largest sway bars... Been wrong before though!!
Old May 3, 2016 | 11:21 PM
1FastBrick's Avatar
A 2500 sway bar will likely be different than a 1500
Old May 3, 2016 | 11:23 PM
Wolftrk99's Avatar
They route the same as the 4wd 1500..... Never meaured one, but end links are same oart number (at least afternarket anyway)
Old May 3, 2016 | 11:35 PM
1FastBrick's Avatar
Endlinks are almost universal across the board.
As far as the bar. I don't see any one offering a 1500 bar that fits a 2500
Also when looking into some budget suspension mods, I measured a 2500 arm Vs a 1500 and they are completely different although the look very similar.
Old May 3, 2016 | 11:44 PM
Wolftrk99's Avatar
Cool good to know...
Old May 4, 2016 | 05:37 PM
LJ93Z28GM's Avatar
Thank you for the info.
Time to see what is local on craigslist being parted.
Old May 5, 2016 | 10:05 PM
2002_Z28_Six_Speed's Avatar
If the lower arms are different on the 2500 I would think the sway bars would not be easily interchangeable.
Time2Kill
Dec 29, 2020 11:36 AM
Mercier
Dec 5, 2016 10:44 PM
Shtbox
Apr 15, 2016 02:25 PM
01SilveradoJakee
Apr 6, 2016 08:30 PM
jbat35
Feb 29, 2016 10:37 AM
