front pinion seal
Old Jul 5, 2007 | 10:38 PM
Derek @ EDO's Avatar
FormerVendor
when you plan on fixing this thing?
I may be able to help
Old Jul 5, 2007 | 10:41 PM
southern_chevy's Avatar
When I get the part numbers hopefully within the next week or two cause with it leaking I need to fix it soon before I **** up the front end.
Old Jul 5, 2007 | 10:49 PM
truckmann's Avatar
Originally Posted by southern_chevy
hey truckmann thanks for the files you wouldnt happen to have the whole file that you could email me? As in anything for the front diff. thanks again
It's a service manual database that runs using an internet browser. So I can't really e-mail the program, but if you pm me an e-mail address and let me know what you need I can make pdf's of the info and send to you.
Old Jul 5, 2007 | 10:53 PM
pm sent I will take any thing for the front diff that you can get. thanks again
Old Jul 5, 2007 | 11:09 PM
jblack6527's Avatar
I just changed the pinion seal on the rearend of my truck, It wasn't too bad, the front shouldn't be any different. I just pulled the d-shaft, took the pinion nut off, got a small two jaw puller to pull the yoke off, and basically hammered the old seal out with a screwdriver. Just hammer it in from the side, and then pry outwards. It takes some effort, but it worked. After I got it out, I just tapped the new one in with a hammer, put the yoke back on, and with a new pinion nut, torqued everything back down and re-installed the d-shaft. Make sure to get a new pinion nut though.
Last edited by jblack6527; Jul 5, 2007 at 11:15 PM. Reason: spelled something wrong
Old Jul 5, 2007 | 11:15 PM
ya that is what I was planning on doing to get it out but I am unsure of the torque spect and what all else you need to replace.
Old Jul 6, 2007 | 02:51 AM
jblack6527's Avatar
All I replaced was the pinion nut and of course the seal. I'm not sure of the torque spec either, I just tightened it back to what felt like where it was.. It worked, but I would torque it if I had the specs.
Old Jul 6, 2007 | 10:01 AM
Well got the seal today it was only 9 bucks. Anyone know of hand what weight gear oil goes in the front? Hey derek What you doing this weekend? Cause if we get rained out again in the morning I might try to put this in this weekend.
Old Jul 14, 2007 | 04:37 PM
Well I got the seal in today only took about 2 hours from pulling it in the shop to moving it out, and that included making a puller for the yolk. It was a lot easier to get to and do than I had thought it was going to be.
Old Jul 14, 2007 | 04:52 PM
jblack6527's Avatar
good to hear man. Glad you got it done
