Front end rebuild and other stuff
Old Jun 6, 2008 | 10:49 PM
Default Front end rebuild and other stuff
I am going to rebuild my front end, new shocks on all 4 corners, new bushings, new bump stops etc. Can someone give me a list or have a link to a list of all the front end items so I can order it all? I was going to do pitman and idler arm as well since I have a weird shimmy in the front that occurs randomly. I figure that with the front end rebuild it will take care of this problem. Oh this is for my 1500HD same suspension as a 2500. Thanks for the help.
Old Jun 7, 2008 | 02:27 PM
Bish's Avatar
I can tell you what I did on my 01 Tahoe at about 140K. Made a HUGE difference as the degradation is gradual and you don't really notice it too much. Not sure if it is the same but it will give you a starting point.
Upper/Lower ball joints
Pitman
Idler
Upper/lower control arm bushings
Inner/outer tie rod ends
stabilizer bar end links
Stabilizer bar bushings (for the bar itself)
I considered replacing the control arms complete with ball joints but didn't want to spend the extra $$ I also did wheel bearings by replacing hubs. Figured I didn't want to tear into it again.
Used a press for the bushings. Spray with silicone before pressing them, makes it MUCH easier. Everything else was pretty straight forward.
Good Luck.
Old Jun 7, 2008 | 05:48 PM
Perfect thats what I needed.
JordanH
Feb 28, 2017 07:22 PM
5.3Caprice
Nov 7, 2015 08:56 PM
Ketis
Jul 23, 2015 12:37 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
JordanH
Jul 14, 2015 03:46 PM
