Front diff slipping bad. Which way to go?
Old Nov 30, 2009 | 12:58 PM
ndependent's Avatar
Registered User
Default Front diff slipping bad. Which way to go?
My brothers front Diff is slipping bad. Was low on fluid and i think he burnt the clutches up. WHat the best to goo? Get another chunck ? Or rebuild the one he has already. Does detroit make something that replace the stock for resonable price ?
ndependent's Avatar
Registered User
Oh its a 2002 chevy 1/2 ton with the 5.3
Old Nov 30, 2009 | 12:59 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Do you mean his transfer case clutches are slipping? The front diff doesn't have any clutches, it's an open differential.
Old Nov 30, 2009 | 03:50 PM
ndependent's Avatar
Registered User
lol im a retard. I guess thats what it is. With him running the fluid low in the front we assumed he messed the front diff up. At first it wasnt pulling that good in reverse and now its bad enough it will barely turn in forward. So giving that info. I guess it is the transfer case?
Old Nov 30, 2009 | 03:58 PM
DV2000NJ's Avatar
13 Second Truck Club
So which had the low fluid, the transfer case, or the front diff?
Old Nov 30, 2009 | 04:41 PM
You have me completely confused now.
Old Dec 1, 2009 | 12:26 PM
ndependent's Avatar
Registered User
lol no the front diff had the fluid that was low.
Old Dec 5, 2009 | 09:15 AM
anarchyracing101's Avatar
Hey this may help ndependent out but me as well. After a summer of high rpm launches on the street in 4hi , I managed to strip sections of teeth of my front diff ring gear and I can actually feel the missing teeth as I go over them now when accelerating. I know I need to swap something out but before I go investing in new front diff gears, is there a stronger alternative available? I read something somewhere a while back about the H2 or the H3 having a better front diff.
Old Jan 9, 2010 | 09:23 AM
Anyone have any knowledge about the front diffs in the H2's and H3's? Didn't they come with like an 8 3/4 diff with 4.10 gears or something?
Old Jan 9, 2010 | 02:16 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
H2's have a 9.25" diff, same one that the HD trucks use. It is not a direct swap into a halfton, it is narrower and frame mounts are different.
Not sure what the H3 uses, but it's probably the smaller halfton unit.
