Forward clutch clearance 4l70e
Old Jul 8, 2016 | 05:08 PM
stolisan's Avatar
Default Forward clutch clearance 4l70e
How do I measure this. Right now there is 0 clearance but if I push down on the plate I can get about 0.040". Without the snap ring , the plate is about 0.015" above the snap ring groove.
I installed the Transgo clutch springs and the Sonnax input drum reinforcing ring and piston. I had to buy another input drum so it not the original. I also measured the new frictions and steels and the forward clutch pack is about 0.030" thicker.
I assume I need a thinner plate to get the clearance? The thinnest one will be 0.046" thinner which should give me 0.031" clearance.
Old Jul 13, 2016 | 09:20 PM
Wolftrk99's Avatar
Almost sounds like something isnt seated properly, but iirc you should have .040-.060 clearance on forward clutch, if your .015 over the retaining ring groove theres defintiely an issue....
smokeshow
Jul 4, 2016 11:05 AM
rick539
Jul 2, 2016 08:49 PM
marketmerlin
Jul 2, 2016 11:07 AM
ke5agx
Jun 27, 2016 10:29 PM
