FLT tranny and converter
I received my FLT tranny w/converter last week and swapped it in last night. In my haste to get it in, I forgot to top off the TC with fluid. Does anyone know if they get shipped with enough fluid in them not to worry?
Nobody answered the phone today (at FLT) and I can just call them tomorrow anyway. I just didn't want to waste time pulling the tranny back down, if i don't have to.
Thanks.
Thanks.
I am going to bet 95% of your tranny shops fire everything dry,with the tires off the ground dump in 4-5 quarts in the fill tube,fire it put it in reverse and let the tires roll while pouring another 5-6 quarts,then run it through all the gears and then start checking the level.Would be best if you had someone start it and put it in rev. so you can start pouring the second it fires.
I will go out on a limb and say FLT will tell him not to pull the trans,go ahead and fire it.Anyone here have a real GM late OE service manual? Would be interesting to see what they say about converter fill and trans start up proceedure.
Here's a little info I found while doing a search on installation.
http://www.converter.com/book_install.htm
Thanks.
Thanks.
as for the TC i dont think they put in any fluid in it.
also, i think FLT will probably agree with da wrench on it. sounds more of a safer method.
