FLT 4L60E Level 5 Installed
Old Jul 11, 2008 | 09:58 PM
Bradazz's Avatar
Originally Posted by BlackGMC
Did you write your tune? The only reason I ask if you did, why did you change the Optimal Timing table? That table is used for the TQ calculation for the computer, and TQ calculations are used for some of your tranny pressure calculations... Since it is lowered that might be why it is shifting soft, then again it might not... I just don't know why it would be changed...
I did some of the tuning but I had quite a bit of help from Jesse (wait4me) because he lives really close to me. You know more than me so I will take your advice, Should I change that table back to stock? I just got back from a drive and it shifts quickly but not firm so I don't know if that is how it is supposed to be.
Old Jul 11, 2008 | 09:59 PM
BlackGMC's Avatar
Resident Retard
I would try putting that table back to stock, do you need a stock file?
Old Jul 11, 2008 | 10:02 PM
Bradazz's Avatar
I know where to get one but if you want to post it here I would apprecaite it. Would there have been a reason that the Optimal Timing table was changed? Thanks for your help!
Old Jul 11, 2008 | 10:09 PM
BlackGMC's Avatar
Resident Retard
Honestly I don't have a clue why that table would be changed... Like I said it is used for TQ calculations.... This is what EFI Live says:
This table is used as a reference for what would be best timing, which is then used for various torque calculations.
Change and go for a spin and then post up what you think. It may or may not solve your problem...
Old Jul 11, 2008 | 10:15 PM
Bradazz's Avatar
Once again, Thanks Alot for your help! I just need to find out what I did with the OBD Cable so I can change the tune. I will let you know what happens.
Old Jul 11, 2008 | 10:34 PM
BlackGMC's Avatar
Resident Retard
Old Jul 11, 2008 | 10:44 PM
gao8302's Avatar
You need to change the title under your username to EFI Wizord!!!!
Old Jul 11, 2008 | 11:04 PM
BlackGMC's Avatar
Resident Retard
I don't know about that, I am learning just like everyone else on this board...
Old Jul 11, 2008 | 11:46 PM
Bradazz's Avatar
I changed the tune and went for a drive. It is still is not as firm as it was but I sure do like it, it has a firmer shift when I get into WOT but not to harsh. This transmission actually shifts where it is suppose to as opposed to my old transmission which wouldn't shift in time therefore I would hit the rev limiter. I logged my drive and below is that file incase you want to check that out.
July 11th 2008.efi
Old Jul 11, 2008 | 11:49 PM
Bradazz's Avatar
I just realized that I didn't log any of the transmission pid's, Sorry about that.
