First time Stall owner: Is my stall "Loose"???
Old 12-16-2010, 03:07 PM
Resident Retard
BlackGMC's Avatar
Originally Posted by viciousknid
If you can put it in gear and just barely increase the throttle to 1500-2000rpm and it accelerates like it did before then it's considered tight. If you barely touch the throttle and it jumps up to 3000 rpm to start moving then it would be considered very loose.
Mine does not act like that and mine is loose as hell... i can put along under 2k decently, but at half throttle it will hit 4k easy.... if you have to rev it to 3k before it even moves then something is broke or the verter is completely screwed....
Old 12-16-2010, 03:22 PM
Wearin' da big hat
00ChevyScott's Avatar
The lockup on that converter is HORRIBLE. It's either in your tune or that converter clutch is toast.
Old 12-16-2010, 04:45 PM
baSICK5.0's Avatar
It's prolly the tune. Hasn't been retuned since the stall. Plus if your talkin bout the second video I let off slightly at the end so it looked like it fell back.
Old 12-16-2010, 04:48 PM
baSICK5.0's Avatar
Oh another question. Say I'm driving along anywhere from 40 to 55 the converter is locked up. It locks and unlocks constantly until I give it heavier throttle and speed up to 55+. Drives me nuts
Old 12-16-2010, 08:04 PM
cdub81's Avatar
Thats the tune man mine did the same and justin changed it in the tune and its fine now and i was gonna say it looks like you had your 3rd gear lockup enabled at the end but if you let off i guess thats what it was... Seems normal to me
Old 12-17-2010, 09:05 AM
baSICK5.0's Avatar
Ill get my buddy to tweak the tune and it should be good.
Old 12-17-2010, 09:22 PM
getonit's Avatar
Man it looks fine to me. Just get your tune worked on. Who do you use on the tune?? Reagan??
Old 12-18-2010, 08:49 PM
Hunt&Fisherator
silver-mod-o's Avatar
Not gonna say I told ya so at all but it doesnt look like anything I'd put in something of mine. The lockup looks terrible tuning or not... My truck with stock tuning, built up trans, and even the stock converter lock nice and crisp...
Like I said, it's based off a front wheel drive converter...
Old 12-19-2010, 05:14 AM
bighoss77's Avatar
3.42 gears and a 3,200 stall? maybe im oldschool, but i thought that was a no no... i had a mustang with stock 3.55 gears and a 3,000 stall and my God it was awful! after some 4.10's everything was a-ok
Old 12-21-2010, 04:07 PM
baSICK5.0's Avatar
It's not like I installed the gears to match anything. They are soon to be replaced. Btw. Why not? I don't believe in overgearing a vehicle. It just doesn't work well. I'm still gonna be able to get decent gas mileage with these gears
Quick Reply: First time Stall owner: Is my stall "Loose"???
