Finsihed up the 4in drop Flip Kit
Old Jun 28, 2013 | 04:51 AM
TIM Z's Avatar
11 sec. Truck Mod
Yeah that is some great looking fab work !
Old Jun 28, 2013 | 09:48 AM
TXsilverado's Avatar
it's tomorrow and we still do not have a go pro vid...
Old Jun 28, 2013 | 11:42 AM
BigKID's Avatar
Originally Posted by BlackGMC
BTW, i had to move the spring perch forward about 7/8 to get the driveshaft lined back up. wierd because i read that most people have to move it backwards...
That is strange. I was thinking that rotating the spring by lowering the rear hanger moved the pin alignment enough to put it on the opposite side of the axle centerline so I threw it in autocad and rotated it. The 2" rear hanger drop didn't move the pin alignment enough to make a significant difference. Here is the illustration...
btw... nice work on the suspension. Makes me want to get out and finish mine. I am curious to hear the final results on ride comfort and traction improvement.
Old Jun 28, 2013 | 01:50 PM
Spoolin's Avatar
GFYS and STFU
Nice job Corey!! I really like the stance, it's perfect the way she sits! Kinda happy about it sticking now too, spinning at 80 mph is fun but after the 3-4th time it gets old.
As far as your exhaust...you could go out the side of the bed.
Old Jun 29, 2013 | 05:23 PM
Beatdown Z's Avatar
Laid Back
It's actually a 5" rear drop since you only altered the rear mounting points of the leaf springs. That's why the truck is sitting level. 0/2, 2/4, 4/6, etc... dropped trucks all still have a bit of rake to them.
It's a good thing it turned out the way it did though, because it looks perfect. Nice job!
Old Jun 30, 2013 | 12:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Looks Clean!!!
Old Jun 30, 2013 | 07:27 PM
DTHPROOF's Avatar
Where did you get the shock brackets, buddy?
Old Jun 30, 2013 | 07:46 PM
BlackGMC's Avatar
Resident Retard
the uppers from here:
High Clearance Shock Tabs
the lowers from here:
Adjustable Shock Mount Housing Bracket with 1 1/2" radius
Bolt-on Shock Mount Bracket - Left Hand
Bolt-on Shock Mount Bracket - Right Hand
Old Jun 30, 2013 | 07:53 PM
DTHPROOF's Avatar
Thank you!
-Josh
Old Jul 3, 2013 | 08:24 AM
53bowtie's Avatar
That is exactly the stance I would like mine to have eventually. Did you use axle shims or did you weld new perches? If axle shims, how many degrees? Thanks!
