extracting trans fluid
Old Feb 18, 2013 | 05:54 PM
40series's Avatar
Default extracting trans fluid
i added too much trans fluid n need to get this stuff out , my dip stick reads way past the hot mark n its been like 3 or 4 days since ive put it ini tried a oriellies syphon it didnt work i tried dis connecting the radiator trans fittings it didnt work work
i need some ideas
Old Feb 18, 2013 | 05:57 PM
03sierraslt's Avatar
Since it was not mentioned I am guessing you dont have a drain plug on your trans pan.
Old Feb 18, 2013 | 06:26 PM
40series's Avatar
Default no drain plug
no i dont have a drain plug..
will this damage some kind of pump in the trans??
Old Feb 18, 2013 | 06:44 PM
Mangled03gmc's Avatar
Baltimore Whore
Pull a line of the trans cooler..
Old Feb 18, 2013 | 06:48 PM
40series's Avatar
Default do i keep the truck running
when i pull the cooler line do i need the engine to be running ?
Old Feb 18, 2013 | 06:56 PM
Baltimore Whore
See what actually runs out of the line first.
Old Feb 18, 2013 | 07:03 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yes.
Edit, don't pull the line while the engine is running. Disconnect the line, and run it to a bucket. Then start the engine.
Old Feb 18, 2013 | 07:16 PM
Baltimore Whore
Or undo both of them and blow air in there
Old Feb 18, 2013 | 08:04 PM
40series's Avatar
Default tried the cooler line not much cam out
Old Feb 18, 2013 | 08:11 PM
40series's Avatar
Default in done for the night
im done re connected the LINe not much came out its getting cold and i have to work in the AM i hope my teans isnt getting ruinedit shows way full butr i know it was a little under when i put a .25 quart in if that 4 days ago WTF.
