Ext. cab guys...2 piece DS question...
Old Jun 24, 2008 | 05:32 PM
Big Red Truck's Avatar
11 Second Truck Club
Originally Posted by Superado
anyone had any problems with the two piece driveshaft?
anyone done any upgrades in regards to the driveshaft on an ext. cab?
this comes up due to a couple of rear ds u-joint bolt heads that I noticed recently during my tranny removal...
a wrench or socket wouldn't fit and when I looked to see why, I noticed that one of the two bolt heads on each cap had evidently hit something...
they appeared to have hit something on itself while spinning under load...
this was where the u-joint attaches to the pinion yoke...
I'll see if I can get pics posted...
I know exactly what’s going on.
Your rear leaf springs are winding up under load and is putting the rear drive shaft & joint in a bind. You are getting ready to spit the drive shaft out. You will need some type of traction bar, ladder bar, pinion snubber, etc.
A good friend of mine had the same thing happen. Been there, seen it, done it.
Should be a fairly easy & inexpensive fix.
Old Jun 24, 2008 | 10:19 PM
Superado's Avatar
I thought that, but I can't imagine it binding that much...
also...I looked closer and the damage to the bolt heads looks old...
the pinion seal is leaking though and that yoke is slinging dope as well...
even though I haven't noticed any drips while parked...
I do have a set of CalTracs...just never installed them once the slicks cured my wheel hop and spinning...
Old Jun 24, 2008 | 10:35 PM
ZZebes's Avatar
Originally Posted by bigbadwolf54
but my trucks an oddball, 2wd ext cab short-short box(the same bed as the crew cab trucks). It doesnt appear much different than a crew cab DS
OMG i'm not the only one
thank the lord another ecssb member
Old May 12, 2012 | 04:23 PM
Superado's Avatar
Originally Posted by ZZebes
AVOID the 1 piece
Back from the dead!
I never asked before...what is the reason for the above statement?
Also, has anyone with a 2pc DS ever converted to a 1pc?
If so...did you use a stock one or have a custom one made?
Aluminum or steel?
Old May 12, 2012 | 04:36 PM
Ferocity02's Avatar
That would be a LONG 1-piece, which I would think would be hard to balance and might be subject to vibrations more so than two shafts of half the length each. My bolt heads had the same issue, it was because my pinion angle as so bad (see pic) than under load the rear rotated up enough to cause binding in the u-joint. I fixed the pinion angle by moving the carrier bearing up several inches and with pinion angle shims and haven't had the problem since. But I would too be interested in a 1-piece if it's possible and safe.
Old May 12, 2012 | 04:40 PM
GMCtrk's Avatar
I'm converting mine to 1 pc. aluminum now, weight savings and much easier to get the driveline angles correct w/ drop and 4l80e swap. Plus I'll get stout Spicer XL u-joints as compared to the crap greasable u joints in there now popping and shitting on themselves.
The only downside is undercarriage clearance and cost. I'm going to try and go with a 4" shaft, but I may need to go to 5" due to the length.
Old May 12, 2012 | 04:42 PM
GMCtrk's Avatar
You drove the truck with that looking like that?
Old May 12, 2012 | 04:46 PM
Ferocity02's Avatar
Yup but not for very long. It actually drove fine, there was a slight vibration around 20mph and a little shudder when accelerating slowly from a stop.
Old May 12, 2012 | 05:36 PM
Superado's Avatar
EC 4x4's have 1pc DS's w/o issues.
The shop I use from time to time was built a TT Dodge SRT10 that makes about 1300hp. They removed the 2pc DS on it and just had a local DS shop make a 1pc steel DS for it that seems to work fine.
Old May 12, 2012 | 05:45 PM
GMCtrk's Avatar
TimZ on here actually has a 1 pc. steel driveshaft in his ECSB that he had made and it does well for him. I know Denny's wont make a steel 1 pc that long. I may ask DSS if they'll make a 1 pc. steel shaft but I doubt it due to the length.
