Engine Mounts and Trans Mounts
Old Jan 27, 2011 | 12:30 PM
SIERRASPEED's Avatar
Default Engine Mounts and Trans Mounts
I own a 07 Sierra just took out an engine mount (by the way they are liquid field ) so the OEM are very cheap $44 but it does not make since to buy OEM since i got a tune, going to end up busting it and buying them again. Looking for polyurethane engine and trans. mounts but no luck, does any one use anything else? beside solid mounts... lol or do they even make anything for our trucks.
Old Jan 28, 2011 | 07:38 PM
I have not found poly engine mounts, but I do believe you can buy a poly trans. mount. I think some have welded the engine mounts so they are essentailly solid mounts.
Old Jan 29, 2011 | 08:36 PM
Mrgoodwrench3's Avatar
I did the Energy Suspension mount on my truck. I don't know of any motor mounts.
https://www.performancetrucks.net/fo...nsion+bushings
Old Jan 31, 2011 | 12:54 PM
Thanks ... well ill keep looking if anything stronger then Poly. ill post the page and item if i find it, thanks again.
Old Jan 31, 2011 | 04:46 PM
Coban's Avatar
Wait, wait, wait, what are the specs on this build?
If you are basically stock I don't think a tune is going to make you start busting more motor mounts. Perhaps the first one was an anomaly.?..
TAPyvehc93
Jul 23, 2017 10:54 PM
1bad2k
Aug 18, 2015 09:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
Mike454SS
Jul 20, 2015 08:52 PM
Deceptarado
Jul 8, 2015 05:24 PM
