ecsb guys-driveshaft question
Old Jan 12, 2010 | 09:13 PM
viciousknid's Avatar
Where's the Beef?
Just adjust the pinion angle to make sure you aren't stressing anything. I'm lowered 2" in the rear but i've driven 110+ for long periods of time and never felt any vibrations at any point.
Long distances being 15-20+ miles at a time in some cases...... Don't ask.
Old Jan 12, 2010 | 09:33 PM
SLOXCAB's Avatar
nice 15-20 miles- when i go over 120 i get a vibration. i might have to try a custom 1 peice just to test it out. ill be the test subject and just keep my two piece just in case
Old Jan 12, 2010 | 09:35 PM
Black'Rado's Avatar
before you get a 1 piece check your pinion angle and your carrier bearing...after i lowered my truck i got a vibe at 100 and it was my carrier bearing....imo i wouldnt run a 1 piece after seeing countless threads on breaking them
Old Jan 12, 2010 | 09:39 PM
SLOXCAB's Avatar
did you replace the carrier bearing?
Old Jan 12, 2010 | 09:40 PM
Black'Rado's Avatar
yea i replaced it with a GM one....it was a revised design
Old Jan 12, 2010 | 10:04 PM
Where's the Beef?
I've taken mine up to 134 (GPS confirmed) with no vibration so I agree that you should check the angle. (this was before my 2" drop).
I don't know when the revised the carrier but Black Rado is 99-02 model and you and I are 03+.
so might check on when they did that.
Old Jan 12, 2010 | 10:07 PM
Where's the Beef?
Another thought..... What kind of tires are you sporting?
Old Jan 12, 2010 | 10:10 PM
BigCountryx's Avatar
stock 2 piece with 4l80 yoke. Had all u-joints and carrier bearings checked, then speed balanced when I swapped trans. No vibes or probs
Old Jan 12, 2010 | 10:38 PM
TXsilverado's Avatar
Originally Posted by siktruk
what about those that are lowered? im a 3/4 right now and going 5/7 in a few months. Does anyone know what Txsilverado is running?
my drive shaft has never been touched. i dont plan on it either until i start feeling some slop in the joints.
Old Jan 12, 2010 | 11:00 PM
SLOXCAB's Avatar
what drop does your truck have
