Drum brake swap for rear bogarts
Old May 22, 2012 | 10:43 PM
  #21
Charlie@LsXperts's Avatar
I was the "buddy" in this post, housing ends were clocked 45 degrees and it bled fine... the calipers are just sitting "up" a little bit on my truck....
Old Feb 7, 2013 | 04:38 PM
  #22
LOstrolencki's Avatar
Originally Posted by 400hp ss
Just did the swap on my 2000 silverado. Had rear disk brakes and as most of you know the 15" bogats will not fit. So a buddy swapped me his rear drums off his 05 serria. Sense no one posts about the brake swap on here ill tell you that everything swapped over perfect didnt have to make anything. Swapped the backing plates, brake lines and e brake cables. thats it. Took a few hours to do and cant tell the difference. Oh his truck only difference is it stops alot better.
just to make sure i read this right, u had stock 16 inch wheels over your factory disc brakes in the rear.. swapped them out with chevrolet stock drum brakes and bogart 15" wheels fit over the drums with out any custum fabrication?
Old Feb 7, 2013 | 05:19 PM
  #23
400hp ss's Avatar
Yep they will fit
Old Feb 8, 2013 | 10:33 PM
  #24
Lilbro's Avatar
From: Right of the rock and left of the cactus, Arizona
What about piston size difference between the wheel cylinders and the calipers? Did you swap out the master cylinder or is it the same for both?
Steve-O-08
Apr 19, 2018 09:32 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
chopperloco
Jul 10, 2016 10:45 PM
Ketis
Jul 23, 2015 12:37 PM
mrgrim
Jul 8, 2015 08:12 AM
