Drum brake conversion on 2002 complete
Old Feb 12, 2006 | 06:02 PM
67SS509's Avatar
10 Second Truck Club
Default Drum brake conversion on 2002 complete
Swapped a 2005 rear axle assembly with drum brakes to my 2002. Now I can run 15" steel or aluminum wheels with as much back space as I want. I'm going to use 15x10" wheels with 30x10.5" slicks for the strip. For the street I'm going to use BFG drag radials 315/60R15 which are 29.8" tall and have a 11" tread. Everything was a perfect swap for bolting up. You just have to use short cab to short cab or extcab to extcab rear-ends because the park brake cables are different lenghts. Haven't driven it yet to see if it needs anything to balance the braking from front to rear. Probably will need a proportional valve and a residual valve in the line to the rear.
Old Feb 12, 2006 | 11:18 PM
hog's Avatar
hog
With your 3.73 gearing I would go with teh BFG 325/50/15 that is 28" tall with a 12" tread. I ran these with 15x10's and they fit and hooked perfect. I went thru the traps at 4800-4900rpm.
This would be much better for your higher revving 5.3.
peace
Hog
Old Feb 13, 2006 | 01:44 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How are you liking the Jesel rockers?
Old Feb 13, 2006 | 04:48 PM
67SS509's Avatar
I,m real pleased with them. My valve train is absolutely as quiet as stock now and I can bounce it off the 7000 rev limiter at will. They were pricey but I would spend it again.
Old Feb 13, 2006 | 05:41 PM
ASkipper's Avatar
11 Second Club
How does that thing run at the track?Any dyno numbers yet?
Old Feb 13, 2006 | 06:14 PM
blk03's Avatar
so, you can run smaller rims with the drums? I have been wondering that for awhile.
Old Feb 13, 2006 | 06:21 PM
67SS509's Avatar
Hope to have some good #'s in a few weeks now that my traction problems may be solved.
Old Feb 13, 2006 | 06:35 PM
1slow01Z71's Avatar
Yeah with drum rears you can run 15" rims that will allow you ALOT more slick choices.
Good deal on the Jesels I cancelled my order for the Jesels I was going to get and put that money towards my new nitrous kit. I think Im going to end up with the same ones you have when I do my next round of mods.
Old Feb 13, 2006 | 06:37 PM
ASkipper's Avatar
11 Second Club
Where have you been running at I might have to make a trip and watch.
Old Feb 13, 2006 | 06:51 PM
67SS509's Avatar
Fayetteville. Come on and join the crowd!
