Drop Shackles
Old Nov 13, 2006 | 08:15 PM
Cuerva's Avatar
11 Second Truck Club
I just installed 2" beltech shackles to the 6" flip kit that I have and don't have any squeeking.
Old Nov 13, 2006 | 10:16 PM
jakebdb56's Avatar
the grease will help a lot.
do the shackles allow for one side to be "lower" than the other. jw, cuz I wanna get rid of the chevy lean. driver side sits a little lower cuz fuel tank, and I'm a fatass
Old Nov 15, 2006 | 01:16 AM
jakebdb56's Avatar
anyone know if they allow for one side to be lower than the other?
Old Nov 15, 2006 | 09:52 PM
blue 01's Avatar
My DJM have two sets of holes. About 1 inch apart. To use the lower holes you have to trim out the radius in the leaf spring clearance area on the shackel so it doesn't hit the round end of the leaf spring.
Old Nov 15, 2006 | 10:38 PM
StrokerAce03's Avatar
I have DJM's and they squeaked when I first put them on. I think I loosed the nuts a little and sprayed the bolts down with some CRC silicone. Any time you go from rubber bushings to polyurethane like is on the DJM you are gonna experience a little squeak. Every poly bushing I've ever seen squeaks a little.
Old Nov 16, 2006 | 11:19 AM
white06's Avatar
The squeaking is coming from the binders on the front and back of the springs. I f they're wet, no noise; dry sounds like ****. Is there anyway to get grease in there?
Old Nov 19, 2006 | 05:48 PM
white06's Avatar
Finally had time to fix it! Had to put a pry bar between the springs until the plastic seperator was loose and then greased the living **** out of them.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Chewy07
Nov 14, 2015 09:46 PM
Gadgetized
Oct 22, 2015 09:06 AM
vmaxpro
Sep 28, 2015 11:10 AM
twake_410
Sep 25, 2015 10:09 PM
