Drop Leaf Questions & Opinions
Old Sep 30, 2014 | 09:26 AM
Slow05CC's Avatar
Avery@texas-speed.com
Default Drop Leaf Questions & Opinions
First off I was wondering if the leaf springs for a ext cab and a crew cab are the same length? I found ext cab drop leafs online, but none for a crew cab??
I cant make up mind between a 2/4, or 2/5! I like the 2/4 but want a little more in the rear to level it out. I have about 1" rake and I want it to sit perfectly level, or close. Even with 0 up front and shackles in the back I was about 1" high. At one point I had a front level +2" and it wasn't level either. FWIW: There is not blocks back there!
I was thinking of a flip kit but not sure how to achieve a 5" drop? Most flips are 4 or 6 inch IIRC. My other option was trying to level it with drop leafs, but I don't know much about them, or if they even work on a crew cab?
Any advice, opinions, or recommendations would be awesome!
Facts: The rear is getting notched regardless of what drop I get. Even with the ghetto drop I have back there now it totally bottoms out, and I hate it! I will be getting new shocks, and new 275/45/20s
Current ghetto drop: Front - Cut stock springs. Stock 33.50" on a 275/55, After being cut 31.50" on the same tire... Rear - Shackles and rear leaf removed. Stock 36.50" on a 275/55. Shackles added and leaf removed 32.50" on the same tire. Fender measurements PF31.50, DF31.50 PR32.50 DR32.25... Cant wait to get an actual drop kit!!
Thanks
Old Sep 30, 2014 | 12:21 PM
terravast4's Avatar
i have a ground force kit that is a 3/5 droop has a slight rake
Old Oct 1, 2014 | 09:13 AM
madmann26's Avatar
Thanks
It's easier to do a flip with a 2in raised shackle. That would give you 4in drop in the back.
Front is up to you. Springs/spindles or control arms are the usual routes people take.
Old Oct 4, 2014 | 09:24 PM
robm-951's Avatar
I did a flip kit, notch and an add a leaf to end up at ~4.5" drop in the rear.
Old Oct 4, 2014 | 11:26 PM
gamble686's Avatar
Flip kit with proper notches is the best way to go for sure.
Old Oct 5, 2014 | 09:11 AM
Slow05CC's Avatar
Thanks for the replies... Ill look into a flip kit a little more. I saw the djm makes a 5" drop, so I may look into that. Maybe a 2/5 will sit level, or if anything a tad of cali.
Old Oct 5, 2014 | 04:56 PM
LS1TRUCKGUY's Avatar
IMO stay away from drop leafs. i know two people not including myself whose drop leafs started sagging over time. mostly on the drivers side. mine is starting to do the same thing. i would suggest a flip kit, then adjust the height with different length shackle like stated above
2500ZL1
Jan 25, 2016 06:30 AM
silver-mod-o
18
Aug 25, 2015 08:18 AM
nickpc82
Aug 10, 2015 09:08 AM
USMCvet0311
Aug 1, 2015 07:45 AM
lxcoupe
Jul 24, 2015 06:01 PM
