Driveway trutrac installers...
Old Feb 18, 2009 | 09:42 PM
budhayes3's Avatar
PT's Slowest Truck
Default Driveway trutrac installers...
Who didn't change gears...Were most of you able to re-use your factory shims and obtain the correct backlash? Did you have to mess with the pinion depth at all?
I've also heard that getting the correct carrier bearings is tough for the 99's, anybody have any info on that?
Old Feb 18, 2009 | 09:49 PM
dirt track racer 81's Avatar
ive always reused the stock pinion shim and never had any problems, thats with motive gears.
Old Feb 18, 2009 | 09:51 PM
bluecajun5.3's Avatar
11 Second Truck Club
on the pinion shim (same here motive gears)
the carrier shims they might fall in place or some in/some out.
Old Feb 18, 2009 | 11:10 PM
StrokerAce03's Avatar
x3 on the shims
I didn't change gears when I did the install and just reinstalled the shims the same as they came out and it lined up perfect. Just remember which shims go where and it should be ok.
Old Feb 19, 2009 | 07:31 AM
bud8fan's Avatar
x4 on the shims
did not change the stock gears either but always check your backlash...
Old Feb 19, 2009 | 07:51 AM
krambo's Avatar
Take some pics of your install! I am going to be doing it as well and would love to see what I am going to be getting myself into...
Old Feb 19, 2009 | 08:00 AM
454navyss's Avatar
we left all of the stock shims in mine, went from 3.42 open diff to stock GM 3.73s and tru-trac, no noise at all
Old Feb 19, 2009 | 10:03 AM
BigCountryx's Avatar
got me considering doing this now, i'm staying with the factory 3.73s just want to dump the g80 before i regret it... i did a 4.56 / Detroit swap in my old Z71 and vowed to never do it again, what a pita, But if it's as simple as swapping carriers and keeping everything else the same, i just may jump into it.
Old Feb 19, 2009 | 11:12 AM
budhayes3's Avatar
PT's Slowest Truck
You'll probably be doing yours before mine...I'm a long way away, just gathering information so I have my ducks in a row when the time comes
Old Feb 19, 2009 | 02:54 PM
built408's Avatar
I have installed 4 true-tracs and I had to adjust the shims on all of them. But I am a picky SOB. Not saying it won't work, just might be alittle noisy.
