Driveshafts Recommendation? + vibrating problem
Old Feb 2, 2007 | 04:48 AM
Spoolin's Avatar
GFYS and STFU
Default Driveshafts Recommendation? + vibrating problem
Upgraded tranny from a 4L60E to a FLT 4L80E-5 and shopping for new/shorter drive shaft. Any recommendations as to reputable brands? Lightweight ones available/advisable?
Also
Acknowledging that it's dumb...having said that, when I hit 115mph there's a vibration that feels like it's coming from the axles, possibly driveshaft but could be wrong and then it stops at 125mph. Truck runs smooth again all the way to 140mph+. Rear is a stock 3.73 I believe. I know these trucks weren't meant to drive that fast but any ideas on what it is and how to fix it? Don't want to blow a shaft or axle on freeway going 150mph...I love this forum too much to not participate!! Lol
Old Feb 2, 2007 | 05:12 AM
wkdivr's Avatar
It's most likely the balance of the shaft. They weren't made to be run to that speed. At the very least, get the balance checked, and make sure it's a high-speed balance. I just ordered a shaft from Denny's Driveshaft, they ALL come with a high-speed balance. Supposedly...there's only a 5 pound difference between steel vs aluminum, I went with a steel shaft with 1350 universals on both ends.
adam1803's Avatar
i would guess the driveshaft is causing your vibration, although its weird that it stops at 125, i would think it should get worse. But the stock driveshaft isn't balanced well enough for those speeds. I get alot of vibration at about 80 with my gear ratio and am shopping for a new shaft as well.
Oh and for the 4l80e, you don't need to have a shorter shaft, just a new yoke.
Old Feb 2, 2007 | 07:31 PM
Spoolin's Avatar
GFYS and STFU
Thanks for the tips, I'm gonna look into my drive shaft and see what I can do about it. Be nice if I didn't have to replace it at all!
Texas5.3_1251
Mar 5, 2016 08:10 PM
ls1curt
Jan 5, 2016 11:33 AM
gaps
Oct 15, 2015 02:53 PM
projectnightcrawler
Sep 30, 2015 10:49 PM
Pimpinpete
Sep 8, 2015 07:39 PM
