Driveshaft Vibration @ about 100 mph.
Old Aug 9, 2006 | 02:34 PM
moregrip's Avatar
what a rush!
Originally Posted by The Breeze
I guess since our trucks were meant to shut down at 100 mph thats all they balance them for.
I have heard this before, never got a confirmation though
Old Aug 9, 2006 | 03:04 PM
silver-mod-o's Avatar
Hunt&Fisherator
well I have had mine ran up to around 140+ before and never gotten any vibes from my ext cab driveshaft with the carrier bearing and all... I think GM sometimes "accidentally" balances them right I may just end up being one of the lucky ones when it comes to that... either way, I'd like to have mine re-balanced for more high speed use. I see over 100mph fairly regularly so I'd like to have a little better piece of mind before I get castrated by a steel tube!!!!!
Old Aug 9, 2006 | 04:45 PM
Cuerva's Avatar
11 Second Truck Club
Don't forget you also lowered it some File. I know that changes your pinion angle. That's probably part of the vibrations. I noticed mine vibrating when I went to 4.10's at about 100mph also and installed 4 deg. shims but it still vibrates some. It does it a little bit then goes away at some point past 100mph so the shims did helped me some.
Old Aug 9, 2006 | 04:56 PM
dewmanshu's Avatar
Moderately Differentiated
doh I was gonna mention alot of things that cause the vibration, but since i didn't see lowering and only a gear swap I just stuck with what appeared to be obvious. Shimming is certainly a helper if you changed your driveline angle.
Old Aug 9, 2006 | 06:07 PM
FILE's Avatar
I did lower it before I put the 4.10's but the pinion did not need to be chimmed. What do you all suggest to correct this. I really don't go that fast on my truck specially when my family is with me but it really bother's me it does this at high speeds. Should I send my shaft to get balanced?
Old Aug 9, 2006 | 06:18 PM
moregrip's Avatar
what a rush!
you need to check your driveline, pinion angles first, and go from there
Old Aug 9, 2006 | 07:19 PM
FLT's Avatar
FLT
FormerVendor
I have to agree with checking these idems. Also would look into getting a good HD steel driveshaft. If you have lowered your vehicle the driveshaft might have to be shortened as well.
Old Aug 9, 2006 | 07:36 PM
JimS's Avatar
I have 4.56's. Haven't notice any vibration at 125 mph. Worries me though and a custom shaft is on the list, along with brakes.
Old Aug 9, 2006 | 08:09 PM
MonteCarlo31's Avatar
2006 Crew Cab 4x4s had a recall on their drive shafts, they replaced mine with a complaint and 100 MPH and no Vibe issues at all (in fact smoother then my blown 1996 monte at 10 mph). Check with the dealer and see if there was a product improvment on yours.
Old Aug 9, 2006 | 08:19 PM
moregrip's Avatar
what a rush!
I was looking at it from an engine rpm/transmission gear perspective, so that for an engine rpm and tranny gear selected being the constant, then the axle/wheels & mph would be the difference.
LOL , I just re-read this and for the life of me don't understand what the hell I was trying to say
