Driveline Clunk, A Greased Yoke It Still Happens
Old Sep 2, 2019 | 02:24 PM
therock's Avatar
Default Driveline Clunk, A Greased Yoke It Still Happens
2005 Silverado Z71 ECSB, 100+k miles. I have lubed the thing several years ago that solved it but now it's back and lube is no help.
It may be something else.
Do these things get so bad lubed splines is no help? Regardless I ordered the nickle yoke w/u-joint and a new rear u-joint because of the mileage and a long shot..
It sounds like its coming from under the passenger side front floor board. I can make it repeat by accelerating and braking.
Thanks
Old Sep 2, 2019 | 07:48 PM
2002_Z28_Six_Speed's Avatar
You can try taking it to a driveshaft shop and have them replace the yoke. probably wont be that much. my factory shaft did that too.
Old Sep 2, 2019 | 08:04 PM
RB04Av's Avatar
5 Year Member
Alotta times, the clunk is because of play in the rear end. (no, not THAT kind of play) Which in turn is usually caused by wore-out pinion bearings. NOT the gears themselves; just, the bearings.
Old Sep 2, 2019 | 11:12 PM
therock's Avatar
Thanks,
I can change the Yoke out and will this weekend and see if the clunk is gone.
If its differential work I'll just swap her out to a trutrack. That G80 behind my Radix has to be getting tired.
Old Sep 4, 2019 | 09:28 AM
There was a bulletin about a number of yokes that were not machined correctly from the factory. That is why I mentioned it!
Old Sep 4, 2019 | 10:23 AM
therock's Avatar
Thanks, I'll report on the new yoke and joints results this weekend.
97_ek
Feb 13, 2020 02:07 PM
sleeperlqx
Mar 3, 2017 02:48 PM
slammedsam
Jan 26, 2016 01:06 PM
00 Z71 Sierra
Oct 2, 2007 07:50 PM
